¡IMR 14500!
AW acaba de sacar las nuevas IMR 14500, descarga máxima 4Amp.
http://www.cpfmarketplace.com/mp/showth ... ost2272984
IMR14500 Specifications :
Nominal Voltage : 3.7V
Capacity : 600mAH
Lowest Discharge Voltage : 2.50V
Standard Charge : CC/CV ( max. charging rate 1.5A )
Cycle Life : > 500 cycles
Max. continuous discharge rate : 4A
Operating Discharge Temperature : -10 - 60 Degree Celsius
Size : 14.07mm ( diameter ) x 48.80mm ( height ) +/- .1mm
Minilinterna con sst-50!!!
Capacity : 600mAH
