NITECORE EC1 "EXPLORER SERIES"
La compre en Intl-Outdoor, por unos 53.50 dolares. Os dejo las specs sacadas de la pagina oficial:
-Features:
• CREE XP-G (R5) LED
• Maximum output of up to 280 lumens
• High efficiency constant current circuit enables maximum runtime of up to 70 hours
• 5 brightness levels
• Powered by 1xCR123A or 1xRCR battery
• Output/runtime (1xCR123A): Turbo 280lm - Hi 200lm / 1hr 20mins – Mid 75lm / 5hr – Lo 25lm / 12hr – Micro 4 lm/70hr
• Momentary push-on strobe and SOS modes
• Dual electronic switches ensure very easy user interface
• Secondary red light mode (0.2 lumen)
• Power indicator light also serves as a battery voltage indicator (accurate to 0.1V)
• Power indicator light serves as standby indicator light when powered down
• Broad voltage circuit accepts both rechargeable and non-rechargeable lithium batteries
• Toughened ultra-clear mineral glass with dual-side anti-reflective coating
• Elaborate alloy reflector is purpose-designed for exceptionally long throw
• Constructed from aero grade aluminum alloy
• HAIII military grade hard-anodized
• Stainless steel bezel retaining ring protects core components from damage
• Detachable two-way anti-rolling clip
• Waterproof in accordance with IPX-8 (2 meters submersible)
• Tail stand function
-Dimensions:
Length: 65mm (69mm reales)
Head Diameter: 25.4mm
Tail Diameter: 22mm
Weight: 42.5g (without battery)
Accessories
Quality holster, lanyard, spare O-ring
Asi llego.
Con la linterna viene un manual en chino, la garantia de Sysmax, una funda, un o-ring de repuesto, un lanyard y una pegatina del recubrimiento de los botones de repuesto.
Es la primera linterna que me llega con una bolsita anti humedad dentro, me gusta el detalle.
Lo primero que llama la atencion es que es muy pequeña. Se que es cuestion de gustos, pero a mi el diseño me encanta. El knurling es original, sigue un patron diagonal con lineas horizontales, el agarre no es espectacular como el de una Roche F12 por poner un ejemplo, pero es suficiente. Los grabados estan muy bien definidos.
Alrededor de la cabeza y los botones, hay unas aberturas horizontales para que disipe mejor el calor, cosa que hace bastante bien incluso en los modos altos. Lleva un anillo de acero inoxidable presionando el cristal, el cual tiene tratamiento anti reflejos por los dos lados. Por encima del anillo sobresale una pequeña corona de ataque prolongada del cuerpo.
El anodizado es de calidad, el color es negro satinado. Salvo un par de cosillas que comentare luego, ha venido sin marcas importantes.
El led es un R5, viene bien centrado en un reflector totalmente liso, bastante profundo y ancho, lo que le da una proyeccion bastante lanzadora.
Las roscas.. bueno, mas bien “la rosca” de esta linterna es cuadrada, ancha y anodizada, solo encontramos una vuelta de rosca, pero que no os engañe, rosca muy bien y da sensacion de robustez. Venia limpia y lubricada.
Es cuerpo de la linterna es bastante delgado, el tapon no pesa apenas. Puede mantenerse de pie en cualquiera de sus dos posiciones. El muelle es robusto y esta bien centrado.
Interior.
El clip es bastante robusto, pero no me gusta que si lo quito quede un hueco que denota que ahi falta algo. Es bi-direccional, se puede enganchar en las dos direcciones. Venia bastante apurado al tapon, por lo que le di un poco de forma dejando mas hueco entre ellos.
La bateria puede dar la sensacion de bailar dentro, pero una vez que la cierras, no se mueve.
Vamos con lo mas novedoso en esta linterna, el interfaz de usuario, el led rojo y los dos botones.
Cuando metes una bateria y cierras el tapon, el led se activa y da un destello cada dos segundos mas o menos, de esta manera esta activado el modo baliza. Se puede desconectar de dos maneras, o quitando un poco de rosca para romper el contacto, o poniendo la linterna en modo bloqueo.
Tiene modo micro, bajo, medio, alto, turbo, SOS y estrobo. Una vez metida la bateria pulsas una vez el boton on/off y la linterna se enciende en modo alto, si pulsas el boton mode vas cambiando entre los modos. Para poner el modo turbo hay que mantener pulsado el boton mode estando encendida, despues de 3 minutos baja automaticamente al modo alto. Los modos SOS y estrobo estan ocultos, para activar el estrobo, hay que mantener pulsado on/off estando apagada, el parpadeo es oscilante, parecido al de las luces de emergencia, el modo SOS se activa manteniendo pulsado mode estando apagada, emite los destellos manteniendo un modo bajo entre ellos.
Estando apagada si pulsamos una vez el boton mode se enciende de manera fija el led rojo, de unos 0.2 lumens mas o menos, el modo bloqueo se activa si estando encendida mantenemos pulsamos el boton on/off, emite un parpadeo y se apaga, de la misma el led rojo se pone a parpadear para decirte el voltaje de la bateria, primero emite unos parpadeos que corresponden a las unidades y luego otros, los cuales corresponden a los decimales. Por ejemplo, si parpadea tres veces y luego 9, tendremos 3.9 volts. Tambien tiene aviso de voltaje bajo, cuando la bateria esta en baja forma, estando encendida emite un parpadeo cada seis segundos, y si ya el nivel es critico, parpadea tres veces seguidas cada tres segundos.
El consumo del modo baliza y el parasitario sobre todo son insignificantes.
En modo turbo y con 16430's, ronda los 410 lumens, la pena es que no tenga un moonlight mode, o lo que es lo mismo, el modo micro mas bajo aun, aunque se supone que eso es cosa del led rojo.
Aqui podeis ver un par de beamshots troteros comparandola con la C10R, el tono es mas frio e inunda menos.
Junto a otras linternas para que podais comparar tamaños.
Un par de detalles que quiero comentar, la zona de las pequeñas aberturas para disipar el calor tenian alguna pequeña marca en el anodizado y la zona donde reposa el clip y uno de los tornillos tambien.
El hotpsot tambien tiene una pequeña mancha, pero apenas se nota.
La funda es de calidad, aunque me gustan mas las tipo Sunwayman, con los laterales elasticos, que asi se ajustan a la linterna.
RESUMEN:
Pues resumiendo, esta linterna me ha sorprendido gratamente, ha pasado a ser mi EDC de cabeza, a la espera de que me reenvien la V11R y vuelva a dudar en cual elegir, jaja. La linterna es bastante potente, lanza una barbaridad para lo pequeña que es y el modo baliza me tiene enamorado, es muy util y practico. Da la sensacion de tener algo importante entre manos, como que esta ahi preparado para lo que sea, no se si me explico. Aparte te sirve de localizador en plena oscuridad, cosa que si es la unica linterna que llevamos y se cae, podemos encontrarla en la oscuridad seguramente o tambien como luz de posicion si lo dejas encendido y te lo enganchas en algun sitio.
El interfaz de usuario una vez aprendido tambien lo veo muy acertado, el modo bajo del led rojo es muy util cuando necesitas ver cosas a mano, y aparte si tenemos la vista acostumbrada a la oscuridad nos va a hacer menos daño que la luz blanca y tambien vamos a pasar mas desapercibidos. La linterna lanza mucho y muy bien, la veo cojonuda para un uso todoterreno, todavia no he podido perderme con ella por el monte, pero salvo usos de muy de cerca donde la inundacion pura es necesaria, este tipo de proyeccion la veo muy acertada. El recubrimiento de los botones a alguien le puede dar la sensacion de ser debil y de que va a durar poco, pero para mi no lo parece, el tiempo lo dira.
Es muy pequeña, pesa poco y tira mucho, yo creo que sobran las palabras, en mi opinion es una linterna totalmente recomendable.
•PROS:
-Potencia
-Tamaño muy reducido
-Buena proyeccion y lanzada
-Diseño novedoso
-Interfaz de usuario
-Led rojo secundario
-Modo baliza
-Calidad de acabados
•CONTRAS:
-Alguna marca en el anodizado
-Pequeña mancha muy poco visible en el hotspot
-El clip puede molestar a la hora de usarla
-Puede que con guantes un poco gruesos los botones sean dificiles de presionar
Segun vaya usandola ya ire actualizando con nuevas sensaciones. Espero que os haya gustado.
