PILAS ALCALINAS RECARGABLES -RAM-
05 Abr 2012 13:48 por Antoniolopez
Ayer, paseando por la calle Barquillo, vi en un establecimiento unas pilas alcalinas "recargables".
Segun las explicaciones, están más que comprobadas y se pueden cargar con los cargadores de NI-MH. ¿?
Soportan más de 100 ciclos y proporcionan como alcalinas que son 1,5 V.
La marca es PURE.
La denominación es: ALCALINAS MANGANESO -RAM-
¿Algun compañero sabe algo de esta tecnologia?
05 Abr 2012 16:36 por Juan_blv
Re: PILAS ALCALINAS RECARGABLES -RAM-
En el mercadona tienes panasonic AA ó AAA el blister de 4 pilas a 9 Leuros. Resisten más de 1000 ciclos de carga con una perdida anual (el 1er año) de un 15%.
Por mucha tecnologia que tenga y 1,5V que ofrezca los 100 ciclos no están a la altura de las modernas LSD con base NiMH.
05 Abr 2012 16:47 por XRAYBoY
Proper use and durability
Although these batteries can be used in any device that supports a standard size (AA, AAA, C, D, etc.), they are formulated to last longest in periodical use items. This type of battery is best suited for use in low-drain devices such as remote controls or for devices that are used periodically such as flashlights, television remotes, portable radios, etc. If they are discharged by less than 25%, they can be recharged for hundreds of cycles to about 1.42 V. If they are discharged by less than 50%, they can be almost fully recharged for a few dozen cycles, to about 1.32 V. After a deep discharge, they can be brought to their original high-capacity charge only after a few charge-discharge cycles.
[edit] Comparison to other rechargeable batteries
Compared with other rechargeable types, the rechargeable alkaline battery is relatively low cost. Cells can be manufactured in the fully charged state and retain capacity well. Their capacity is about 2/3 of primary cells. Being of dry-cell construction, they are completely sealed and maintenance-free. Cells have a limited cycle life, which is affected by deep discharge; the first cycle gives the greatest capacity, and if deeply discharged a cell may only provide 20 cycles. The available energy on each cycle decreases. Like primary alkaline cells, they have a relatively high internal resistance, making them unsuitable for high discharge current (for example, discharging their full capacity in one hour). [1]
http://en.wikipedia.org/wiki/Rechargeab ... ne_battery
:negativo:
05 Abr 2012 19:35 por Antoniolopez
Total.
Que parece que no son ninguna novedad.
La cuestión, es que no estan muy divulgadas.
05 Abr 2012 23:33 por antiparanoico
Antoniolopez escribió:...
Es que no valen la pena. Como se dice en mi país: "No gastes pólvora en chimangos".
Un proveedor habitual me las recomendó, pero también me vendía un cargador específico para ellas. Estuve investigando en esa época y realmente necesitan un cargador especial y este era caro, costaba si no me equivoco como un "smart charger" de los buenos. Además de ser para uso "low drain".
Tirando números preferí seguir usando mis kits (cargador + baterías) Eneloop. Una Eneloop de 2ª generación me cuesta lo que cuatro alkalinas comunes de marca (Duracel, Energizer, ...) y tengo cuatro cargadores NC-MDR02NU con más de cinco años de uso (funcionando fielmente como el primer día) que vinieron, cada uno, con dos Eneloop de 1ª generación de las que descarté solo un par, los demás: con muy buena salud. En dos horas cargadas desde casi cero a full y con "high drain".
Por lo tanto ("yo y solo yo") me quedo con las Eneloop. Las alcalinas para el tensiómetro (en el que duran unos cuatro años) y descartable.
06 Abr 2012 20:45 por Bulb-o
http://www.forolinternas.com/viewtopic.php?f=6&t=2168
http://www.forolinternas.com/viewtopic.php?f=6&t=2025
Ese tema ya está muy discutido, te recomiendo que revises esos hilos de arriba.
What about alkaline batteries designed to be recharged?
Paradoxically, these higher-priced specialty batteries, known as RAM batteries, or Rechargeable Alkaline Manganese, are not rated highly in technical reports. Some trade magazines list them as rechargeable for only 25 to 30 times at the most. They are not satisfactory when used in high-drain applications such as digital cameras, as the voltage supplied by the battery drops low in response to high current demands. One battery sales representative referred to RAM batteries as being 'soft' batteries. (His company did not make RAM batteries at the time, and still does not.)
Fuente: http://www.allaboutbatteries.com/Alkaline-charging.html
Para facilitárselo a algunos; no dan un buen rendimiento en aparatos de alto consumo (como linternas) y encima no pueden recargarse más de 30 veces, lo que to puedo confirmar en la práctica. Ojo, que para un despertador o para un mando a distancia van de vicio y permiten mucho ahorro en alcalinas no recargables. Si esos aparatos admiten bien las NI-MH de baja autodescarga con sus 1,2 voltios mi consejo es olvidarse de las alcalinas recargables y su necesario cargador específico.
06 Abr 2012 21:54 por Antoniolopez
Bulb-o escribió:http://www.forolinternas.com/viewtopic.php?f=6&t=2168
Pues muchas gracias por tanta y tan concisa información.
De momento, a olvidarse uno de estas pilas.
