Pedida UF-2100 1000LM 5-Mode CREE XM-L T6
Specifications:
LED Flashlight is water and shock resistant
Water and scratch resistance glass lens
Easily cope with the wild harsh environment
The LED flashlight is made of high quality material
LED Flashlight is compact sized, classical appearance and advanced craftsmanship
High-strength, low weight throw is not afraid, not afraid of pressure and durable
This Cree LED Flashlight is climbing, camping, hiking and other sports field preferred tool
Brightest LED Flashlight usually at home can also be used for reading, repair, prevent power failures, one of more use
Lumens: 1000 Lumens
Lamp Assembly: CREE XM-L T6 LED
Battery: 1 x 18650 Li-ion Battery
5 Mode: High, Mid, Low, Strobe, Fast Strobe
Shell Material: 6065 T6 Aluminum
Que os parece??
