Re: [Proyecto] Montar linterna con XM-L RGBW
Además...
Solo de leerlo he necesitado una aspirina
Tactical forward clicky switch
Basic
Turn on the light by pressing the tailcap button until it clicks.
Twist the head to select between three output levels.
You can pre-selected output level before turning on the light.
Advanced
Change the LED color: Loose the head (3rd level), tight the head (1st level), and then loose the head (3rd level) within one second to change the LED color. Flashlight will light up four different color one after another, tight the head anytime to select your desired color. This color will be your default LED color until you reprogram it.
Cycle through auxiliary modes: Tight the head (1st level), loose the head (3rd level) and then tight the head (1st level) within one second to access this feature. Repeat it to cycle through all settings. Turn off the light or loose the head to quit.
X 1234
