Bigblue TL2500P
Light Source 3x XML LED
Light Output 250-2500 lumens
Casing Material Aluminum alloy, anti-corrosive anodized
Power Source 32650 Li ion rechargeable battery pack
Angle Of Light Beam 10° narrow beam
Safety Designs Double o-ring sealed, safety valve
Color Temperature 6500K
Available Colors Black
Burn Time I=15hrs, II=6hrs, III=3hrs, IV=1.5hrs
Maximum Depth 100M
Size D 63mm x L 139mm
Grip Goodman-style glove, and Lantern-style handle
Weight 457g (including battery)
Bouyancy In seawater -227g (including battery)
Switching System Push button with battery indicator
Front Glass Tempered optical glass
Lantern Handles Aluminum lantern handle included
Megalitium 5
 •PESO: 370 gr.
•LARGO:  128mm.
•DIAMETRO: 42mm. El cuerpo. El cabezal 65 mm.
•BATERIA: formato 32650 3,7v. 5.500mA.
•LED:  5 XPG-2  330 X 5 lumen
•INTERRUPTOR: Magnetico mediante pulsador. on – off- ajuste de intensidad. Modo estrobo
•OPTICA:  10º de apertura.
