Nueva version - Thrunite TN30 y TN31
09 Ene 2013 14:16 por Edgardo
Thrunite TN31
LED: Cree XM-L2 LED with a lifespan of 20+years of run time.
· Max 1376 lumen output using 3 * 18650 batteries.
· Level 1: 0.6 lm. 2000 hours; Level 2: 23 lm. 140 hours; Level 3: 175 lm. 22 hours; Level 4: 439 lm. 9 hours;
· Level 5: 744 lm. 5 hours; Level 6: 1376 lm. 2 hours; Standby: 65 uA; Strobe: 1376 lm. 4 hours.
· Working voltage: 4V to 13V.
· Max runtime: 2000 hours.
· Max beam distance: 840 meters.
· Peak beam intensity: 90000cd.
· Impact resistant: 1.2 meters.
· Waterproof to IPX-8 standard, 2M.
· 201.70mm length, 79.00mm bezel diameter.
· Weight: 452.80g without battery.
· Aircraft grade aluminum body structure.
· Premium type III hard anodized anti-abrasive finish.
· Ultra-clear tempered glass lens with anti-reflective coating.
· Momentary forward click tactical switch.
· Strobe mode for tactical and emergency use.
· Smooth reflector for max light output.
· Highly focused beam for maximum distance.
· Tactical knurling for firm grip.
· Streamlined body design.
· Mechanical reversed polarity protection design for battery carrier.
· Intelligent highly efficient circuit board design for max performance and long run time.
· Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoor activities.
· Intelligent temperature controlled light output for user safety.
09 Ene 2013 15:53 por Marcos Ros
Re: Nueva version - Thrunite TN30 y TN31
Tranquilidad en el ambiente, no va ha haber sustanciales diferencias, ni las anteriores versiones tinen tantos lumens como anuncian ni estas tampoco.
En lo que respecta a la TN30 la anterior version anunciaba 3000 lumens que es totalmente falso, y la de ahora anuncia 3600 lumens, total nada, para mear y no echar gota.
Independentemente de que se trate de lumens a los que sea necesario aplicarles un coeficiente de corrección chino (nºlumens x0.80), en una multiled potente, 200 lumens arriba o abajo apenas los notaras.
09 Ene 2013 21:45 por Jaipe
Marcos Ros escribió:Tranquilidad en el ambiente, no va ha haber sustanciales diferencias, ni las anteriores versiones tinen tantos lumens como anuncian ni estas tampoco.
Yo tambien pienso que poco se notará esos lumens extra pero bueno está bien que vayan haciendo cosillas, por cierto Marcos ya que comentas que las anterior TN31 no dan lo que anuncian, ese video es de una TN31 y parece que si los da, bueno yo entiendo poco pero al menos el luxometro si marca mas de los 1150 lumens que anuncian para la TN31 http://www.youtube.com/watch?v=2e8WQoEEpiU esta trucao o me pierdo en algun sitio?. :comor:
12 Ene 2013 17:40 por san san
http://www.thrunite-store.com/new-arriv ... light.html
porque la reina ya está en casita, sino.....
