New Announcement: L18 Tactical Far Throw Distance Flashlight
Subforo dedicado de Acebeam
23 Sep 2020 09:14 por Acebeam
Profesional
  • Maximum output 1500 lumens with a throw of up to 1000 meters.
  • Can be mounted on different kind of guns with proper equipment.
  • Compatible with Acebeam ARPS-R02 Remote Pressure Switch.
  • Capability to run either on a single 21700 or 18650 rechargeable battery.
  • 1-meter impact resistance, IP68 waterproofing, and reverse polarity protection, you can count on this light wherever duty takes you.
Click and get more information: https://www.acebeam.com/l18
12 Oct 2020 09:18 por Acebeam
Profesional
Re: New Announcement: L18 Tactical Far Throw Distance Flashlight
Acebeam escribió:
23 Sep 2020 09:14
The Acebeam L18 uses 1 x Osram KW CSLNM1.TG LED, TIR reflector and 1 x 21700 Li-Ion battery. The powerful emitter in this flashlight provides up to 1500 lm output, 250000 cd intensity, and a beam distance of 1000 m.
It uses a TIR lens to form the beam pattern. This light has 6 modes of lighting. The memory function is a nice feature, the light will remember the last used mode. It has a strobe function, which is one of the most effective self defense tools available. View more:
27 Oct 2020 11:44 por Acebeam
Profesional
Acebeam escribió:
12 Oct 2020 09:18
Acebeam escribió:
23 Sep 2020 09:14
Última edición por Acebeam el 27 Oct 2020 11:45, editado 1 vez en total.
27 Oct 2020 11:45 por Acebeam
