Thrunite T20 + T1 free
09 Oct 2012 20:16 por Edgardo
Bueno gente, no me quedó otra opcion que pedir la Thrunite T20 + la T1 free. :buitre: :buitre:
Le tuve que explicar a mi esposa que la culpa es de ForoLinternas :silbando: , que si hubiese sido por mi no la compraba..
Specifications:
- Cree XP-G LED (R5) with lifespan of 50,000 hours
- Three modes of output: High (185 lumen, 1.8hrs) -> Low (22lumen, 13hrs ) -> firefly(0.09lumen 195hours) with memory
- Stable current regulated circuit, stable brightness
- Uses one 3V CR123a battery. 16340 batteries are not recommeded, because they heat up quickly.
- 19-gram weight (excluding batteries)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Waterproof to IPX-8 Standard
- Toughened double ultra-clear glass lens
- Reliable twist switch
- Candle mode (Capable of standing up securely on a flat surface to serve as a candle)- Accessories: key ring.
- Size: 63x20mm
Promotion:
Notice:
Ti is promotion for free
3 lumen version: All five colors black, blue, red, green, gold are available.
Ti specifications:(3-60 lumen version)
- Uses Cree XP-E R4 LED with a lifespan of 50000 hours
- Uses one 0.9-1.5V AAA (Ni-MH, Alkaline) battery
- 7.2cm (Length) x 1.4cm (Diameter)
- 20-gram weight (excluding batteries)
- OP reflector
- Reverse polarity protection, to protect from improper battery installation
- Reliable twist switch. Tighten for Firefly (3lumen) tighten further for max Output (60 lumen)
Operation:
Slightly twist the head tighten to firefly(3 lumen), tighten further for max output (60Lumen)//www
Última edición por Edgardo el 09 Oct 2012 20:52, editado 1 vez en total.
09 Oct 2012 20:23 por Noctiluco
Re: Thrunite T20 + T1 free
Me encantan estas pequeñajas potentes, si son de calidad como Thrunite más, y la Ti de regalo te va a gustar, me gusta el knurling agresivo que lleva la que pedí, saludos
09 Oct 2012 20:33 por macofe
Yo pedí la T10, junto con la TI de regalo, y me encantan las dos, si bién en la T10 no me entran todas la baterías recargables que tengo, salvo las de Apple, el resto, que son las Tronic de LIDL, no hay manera. Escribí a Thrunite, sobre el asunto, pero, de momento, la callada por respuesta.
10 Oct 2012 00:29 por miguel41
Yo también la tengo pedida desde el dia 2 de octubre y aun no se nada, en mi cuenta solo pone "Processing". Alguien sabe el tiempo que tarda esta gente en enviar las linternas.
10 Oct 2012 07:09 por macofe
10 Oct 2012 14:45 por Edgardo
Por suerte la despacharon rapido, ayer la compré y hoy me llegó el mail de Thrunite que me avisa que fue enviada y tambien me dieron el numero de Tracking, por logica llegaria en 20 dias.
10 Oct 2012 19:50 por Noctiluco
A mí con la Ti me tardaron 17 días entre el pedido y la linterna en casa
22 Oct 2012 20:47 por Edgardo
El sabado me llegaron la T20 con la Ti, pero como todavia no me llegaron las 2 baterias CR123a pedidas a Manafont, y al tener solo una CR123a, no pude comprarla con la Nitecore MT1C que es la otra EDC que tengo.
Cuando lleguen las baterias hare la comparacion y les comentaré el resultado.
22 Oct 2012 22:20 por miguel41
Hoy he recibido las mías, la T20 la he probado con unas cr123 pedidas en buyincoins el día 2, enviadas el 4 y recibidas el 15 de Octubre, y me ha encantado, estoy deseando que me lleguen unas 16340 también de buyincoins para ver que tal tira.
La Ti la he probado con nimh y luce como la E09 con el mismo tipo de bateria, pero con 10440 es un cañoncito de luz. Me encantan las dos.
Aquí os dejo las enlaces de las baterías, hasta ahora buyincoins en mis pedidos ha sido muy rápido y sin problemas.
http://www4.buyincoins.com/new_en/detai ... t-232.html
http://www4.buyincoins.com/new_en/detai ... t-229.html
22 Oct 2012 23:34 por Edgardo
Hola Miguel41,
Segun Thrunite no recomienda el uso de las 16340 en la T20, te vas animar de todos modos a usarla?
La 10440 que vos decis que probastes en la Ti tiene 3,6 v., no corre riesgo?
23 Oct 2012 00:42 por miguel41
Según la review de F. Premens http://forolinternas.com/viewtopic.php?f=5&t=4730 le ha puesto varias cargas de litio a la Ti y sin problemas, me imagino que se calentará mas y mas pronto.
Y respecto en atreverme con la T20 y 16340 si en la Ti de 1.5 v de una AAA a los 3.7 del litio, no hay mucho problema, yo creo que menos habrá de los 3 v de cr123 a los 3.7 de una 16340.
Un saludo y ya comentaré cuando reciba las 16340.
23 Oct 2012 01:34 por Edgardo
miguel41 escribió:Según la review de F. Premens http://forolinternas.com/viewtopic.php?f=5&t=4730 le ha puesto varias cargas de litio a la Ti y sin problemas, me imagino que se calentará mas y mas pronto.
Me sorprende lo audaces que son.. :respeto: :sisi3:
