Imalent New released DM70 LED flashlight
Suboforo dedicado de Imalent
05 Jul 2019 10:24 por Imalent
Profesional
Product Introduction
The Imalent DM70 is a rechargeable flashlight with compact size but high performance. Only 115 mm in length, this compact body emits a max output of 4500 lumens and beam distance of 306 meters. It uses one micro USB rechargeable 21700 Li-ion battery. Included magnetic tail cap which can release your hands free for working. In addition, the indicator on the switch displays real-time battery status, 5 output levels plus strobe mode, cater for daily use, outdoor activities and repair work.
Product Features
Utilizes oneCREE XHP70 2ndgeneration LED. The lifespan up to 50000 hours with maximum output of 4500 lumens.
Thanks to the integrated clip and magnetic tail cap, the DM70 is perfect for hiking, campaign, machine repairs, and other activities where regular lights fail.
Built-in one micro USB rechargeable 21700 Li-ion battery
Sleep tight light: Our DM70 emits a red light that helps you sleep. Emitting red spectrum lights between 590~610 nm wavelengths helps your body create more melatonin that gives you a relaxed and pleasant feeling that helps you get deeper and better sleep.
Candle function
Product size: 115(length)*33(head diameter) *25.6(diameter) mm
Net weight:87g/160g(battery included)
High efficiency constant power circuit will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum OP reflector
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment
IPX-8 standard waterproof (2 meters submersible)
1.5m impact resistant
