Imalent R90TS flashlight
Suboforo dedicado de Imalent
28 May 2019 11:04 por Imalent
Profesional
1. R90TS, “Night Sword”,utilizes18pieces of American CREE XHP35 HI LEDs with a maximum output up to 36000LM and long range up to 1750 meters, R90TS will bring you absolute shock in the night.
2. R90TS is extremely compact and comfortable to hold, and good for camping, Searching, fishing and more other outdoor lighting experience!
3. The built-in radiator helps dissipate the heat through the heat-pipes, which are then exhausted and cooled thanks to the integrated fans’ strong winds… and all this while being water proof! The ultimate combination of power and technology. 4.With IMALENT’s unique design with bright plating process optical reflector and 18pcs CREE XHP35 HI LEDs,the R90TS delivers a max output up to 36000lumens and a far reaching distance of 1750meters, push you boundaries day and lights, make it a perfect search and rescue flashlight!
5.The R90TS features IMALENT’s signature high-grade side pressure switch. This ergonomic design provides an unprecedented level of grip. Eight output levels ensure long runtimes with low or high output in any situation. The “hide strobe” feature keeps you safe by starting quickly at critical moments.
