Imalent MS18 flashlight
Publicado: 28 May 2019 10:45
por Imalent
1. MS18, “Ambassador of light”,utilizes18 pieces of American CREE XHP70 2nd LEDs with a maximum output up to 100,000LM and long range up
to 1350 meters, MS18 will bring you absolute shock in the night.
2. The multi-functional OLED display can show various parameters and settings. 3.Built-in heat pipe radiator with excellent heat dissipation,
and equipped with an inlet and outlet fan silent,waterproof,heavy wind , which is a perfect combination of great energy and technology.
4. With IMALENT’s unique design with bright plating process optical reflector and 18pcs CREE XHP70 2nd LEDs,the MS18 delivers a max
output up to 100,000 lumens and a far reaching distance of 1350meters, push you boundaries day and lights, make it a perfect search and
rescue flashlight!
5. The MS18 features IMALENT’s signature high-grade side pressure switch. This ergonomic design provides an unprecedented level of grip.
Eight output levels ensure long runtimes with low or high output in any situation. The “hide strobe” feature keeps you safe by starting quickly at
critical moments.
