IMALENT R90C Flashlight
Suboforo dedicado de Imalent
03 Ene 2019 11:14 por Imalent
Profesional
1.Utilizes 9 pieces of American CREE XHP35 HI LEDs with a maximum output up to 20000LM and long throw up to 1679 meters,R90C will bring you absolute shock in the night.
2. R90C is extremely compact and comfortable to hold,and utilizes 6 side lights for camping, fishing and more other outdoor lighting experience!
3.With IMALENT’s unique design with bright plating process optical reflector and 9pcs CREE XHP35 HI LEDs, the R90C delivers a maximum output up to 20000 lumens and a far reaching distance of 1679 meters, push you boundaries day and lights, make it a perfect search and rescue light!
4.The R90C features IMALENT’s signature high-grade side pressure switch. This ergonomic design provides an unprecedented level of grip. Six output levels? ensure long runtimes with low or high output in any situation. The “hide strobe”
feature?keeps you safe by starting quickly at critical moments.
Features:
Utilizes 9 pieces of American CREE XHP35 HI LEDs, with a lifespan of up to 50000 hours and a maximum output of 20000 lumens.
Built-in self-testing intelligent charging circuit which is convenient, fast and safe.
Six power levels which can be changed quickly with instant turbo available.
Battery capacity indicators show the battery level at any time.
Size: 206mm (length)*129.5 mm (head diameter) *55.5mm (body diameter)
Net weight: 1250g (battery included)
High efficiency constant current circuit maintains consistent brightness
Built-in thermal control module automatically adjusts the brightness output to
keep the unit from overheating.
Combination of toughened ultra-clear mineral anti-reflective coated glass
Aluminium SMO reflector
Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment
Waterproof to IPX-8 standard. (2 meters submersible)
