DM21T Utilizes CREE XPL HI LED, 1000 lumens maximum output
Publicado: 13 Jun 2018 10:59
por Imalent
Configuration of the latest CREE XPL HI LED light source, the output brightness up to 1000 lumens, IMALENT DM series of achievements in the industry using a single battery single LED in the most powerful flashlight tactical full-tail control switch, the operation more convenient, you can use conventional 18650 lithium Ion battery and CR123A battery as a power, pocket size compact design, with convenient and efficient two-tailed control switch, to provide you with the best lighting experience.
Product Features
Utilizes CREE XPL HI LED, up to 1000 lumens maximum output
Rotate the tail cap to get infinite brightness, one-handed operation, ease to use
Max beam intensity 16200CD
Max throw distance 268 meters
Designed for fast adjustment of brightness and various modes
Built-in USB charging interface
The charging circuit utilized constant voltage charging mode
Both flashlight head and tail were physically constructed with reversed battery protection
All conductors surface were connected with gold plating, making it to the lowest conducting
resistant possible and antioxidant.
Can fit multi-functional flashlight holster
Ultra-clear tempered glass lens anti-scratches and impact resistant
Optimized deep quality metal reflector to maintain great throw distance and wide spread
beam pattern
The flashlight body made with Aerospace-grade aluminum alloy
Military Grade Specification hard anodized HA Type III
IPX-8 standard waterproof
