Imalent RT70 is high performance flashlight
Suboforo dedicado de Imalent
02 Jun 2018 05:04 por Imalent
Profesional
Imalent RT70 is a portable USB magnetically charged high performance flashlight - a smart aid for night outdoor searching and rescuing and industrial tasks, as well as a backup lighting tool for your self-driving journeys.
Six output levels and hide strobe, ensures you can have long runtime with low output or high output when needed, so you can plan and prepare for your nighttime outdoor journeys and activities well in advance.
The RT70 will illuminate the road and guarantee your safety outdoors.
RT70 is fitted with one latest upgraded CREE XHP70 2nd generation LED, delivering 5500 lumens of output and a beam distance of 903 meters.
Considering the user interface, the RT70 is fitted with user-friendly side pressure switch for stepped light regulation to control the runtime and output selection. This versatile light caters for multiple output level demands.
Product Features
·Utilizes one American CREE XHP70 2nd generation LED, with a lifespan of up to 50000 hours and a maximum output of 5500 lumens.
Built-in safety self testing intelligent charging circuit, convenient, fast and safe.
Six levels which can be exchanged quickly and instant Turbo.
Battery capacity indicators besides power switch, shows the capacity any time.
Size: 161mm (length)*86 mm (head diameter) *51 mm (body diameter)
·Net weight:420g/620g(battery included)
·High efficiency constant current circuit will maintain constant brightness
·Built-in thermal control module will automatically adjust the brightness output, keep
using comfortably.
·Combination of toughened ultra-clear mineral and anti-reflective coating glass
·Aluminium OP reflector
·Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface
treatment
·IPX-8 standard waterproof (2 metres submersible)
