Introducing New Longest Range Hunting Flashlight - L19
Publicado: 18 Dic 2020 12:16
Are you looking for the longest throw flashlight ? The new Acebeam L19 is the last edition in our Long Range series of hunting lights which is the right one for you. The most notable feature of L19 is designed by the LED core technology of auto level. It has a very long throw advantage after comparing with the same size of LEP W30 or the same grade items.
The Farthest Throwing
The L19 is a huge beast that could reach 1300m (4265feet) throw,1650 lumens output. You can easily spot a target in any conditions.Offering green light for option which boasts an impressive throw distance of 1520m (4986.8feet). It doesn’t frighten animals and its beam can’t be seen from aside so it makes impossible to disclose your location. With six brightness settings (plus strobe) and a soft, balanced beam, the L19 is incredibly compact for a searchlight of its power level, and is easy to carry while hunting, hiking or on a search and rescue expedition.
Dual Side and Tactical Tail Switch
Full press to turn the L19 on, and tap the tactical tail switch for momentary illumination,Easily cycle through the four output modes (low → high) by tapping the side-switch, or 3 clicks in any condition to activate Strobe. The intelligent memory function will recall your last used output for quick access. Power indicator for real-time battery monitoring. The L19 has a body diameter of 1" so it is compatible with most weapon mounts. The side switch is for an everyday activation and the tail switch can be used for tactical purposes or remote pressure switch attachment.
Intelligent Design
The Acebeam L19 powered by a single high capacity 21700 battery(excluded), a Acebeam USB-C rechargeable 21700 battery with a whopping 5100mAh capacity is recommended, is also compatible with 1x18650/2xCR123/2xRCR123 batteries by using the included 18650 battery holder.To keep the flashlight and battery protected, it has a constant current and temperature regulation system. This ensures a steady beam of light and prevents overheating during extended use.
Learn more: https://www.acebeam.com/long-range-hunt ... shlight-19
Intelligent Design
