Infinitely Variable Brightness 1 x AA Headlamp 1050Lumens
Subforo dedicado de Acebeam
19 Ene 2019 05:07 por Acebeam
Profesional
Acebeam released 1 x AA Mini Headlamp H40
There are available 2 version CREE XP-L HD LED cool white and SST-20 CRI 95+ LED warm white for option. Let's view more:
Features:
Option 1:
1.1xCREE XP-L HD LED
2.Powered by 1xLi-ion (700mAh)/ Ni-MH (1900mAh) / Alkaline battery (excluded)
A)1xLi-ion (700mAh) battery:
Ultra-Low: 5 lumens; 17 hours
High∞Low: 230∞20 lumens; 65 mins ∞ 7 hours
Turbo: 1050~350 lumens; 1min + 40 mins
SOS: ~, 12 hours
B)1xNi-MH (1900mAh) battery:
Ultra-Low: 5 lumens; 43 hours
High∞Low: 230∞20 lumens; 85 mins ∞ 16 hours
Turbo: 250 lumens; 80 mins
SOS: ~, 18 hours
C)1xAlkaline AA battery:
Ultra-Low: 5 lumens; 52 hours
High∞Low: 230∞20 lumens; 68 mins ∞ 19 hours
Turbo: 250~130 lumens; 2 mins + 70 mins
SOS: ~, 7 hours
3.Max output up to 1050 lumens
4.Max running time 52 hours
5.Max beam distance 102 meters
6.Peak beam intensity 2600cd
Option 2:
1.1xSST-20 CRI 95+ LED
High∞Low: 150∞20 lumens; 65 mins ∞ 7 hours
Turbo: 600~220 lumens; 1 min + 40 mins
SOS: ~, 12 hours
High∞Low: 150∞20 lumens; 85 mins ∞ 16 hours
Turbo: 180 lumens; 80 mins
SOS: ~, 18 hours
C)1xAlkaline battery:
High∞Low: 150∞20 lumens; 68 mins ∞ 19 hours
Turbo: 180~100 lumens; 2 min + 70 mins
SOS: ~, 7 hours
3.Max output up to 600 lumens
5.Max beam distance 106 meters
6.Peak beam intensity 2832cd
7.Impact resistance: 2 meters
8.Waterproof: IP68
9.Size: 64.7x26.9x23.4mm
10.Weight: 34g without battery
11.Single button switch for controlling infinitely brightness
12.Constructed from Aero grade Aluminum Alloy
13.Robust HAIII military grade hard-anodized
14.Confirmtable Elastic Headband with sweat channeling and reflective
15.Over-heat protection to avoid high-temperature of the surface
16.Toughened ultra-clear glass lens with anti-reflective coating, which achieves a 98.3% light transmittance
