ACEBEAM Photo Contest for L30 GEN II / T36 / UC15
Publicado: 08 Ago 2018 12:39
por Acebeam
*ACEBEAM Photo Contest for L30 GEN II / T36 / UC15*
Dear All, now it is the time to win FREE lights :aplauso:
Rules as below:
1. Comments with the outdoor beam shots photos below this post (the photo MUST be lighted by ACEBEAM products only you are using and MUST be taken by YOU) ;
2. Once the photo is selected, it is required to send ACEBEAM the clear photos in focus without blurry shots in JPG with 1920 x 1000 pixels;
3. ACEBEAM (SHENZHEN ZENBON TECHNOLOGY CO., LTD) has the right to use submitted photographs for marketing purpose.
The deadline will be September 7th 2018.
(Any questions about this contest, please PM or email to cora@acebeam.com.)
PS: Photographs must be lighted by ACEBEAM products only, and must be legal, and not infringe upon intellectual property, privacy or publicity right of any third party.
Gift 1: T36[/color]
1xCree XHP35 HI LED
Max.2000 lumens
1x21700 5100 mAh battery (Working temperature: -30 ~ 80℃)
Modes: Ultra Low / Low / Med / High / Turbo / Strobe
Max. runtime: 20 days
Max. beam distance: 303 meters
Peak beam intensity: 23000cd
Waterproof: under water 5m
2 Independent switches for easy operation
Type-C charging port with triple charging speed
Special designed aggressive strike bezel
Gift 2: L30 GEN II
1 x Cree XHP70.2 LED
Max. 4000 lumens
1 x 21700 5100 mAh battery (Working temperature: -30 ~ 80℃)
Modes: Firefly / Low / Mid / High / Turbo / Strobe
Working voltage: 3V - 8.4V
Max. runtime: 65 days
Max. beam distance: 373 meters
Peak beam intensity: 34800cd
Micro-USB charging port
Gift 3: UC15
1xCree XP-L /Nichia 276A 365nm/Cree XPE-R2 LED
White light: Moon / Low / Mid / High / Turbo / Strobe
Red Light + UV Light
When using 2x10440 batteries or 2xAAA (Alkaline/Ni-MH) batteries
Working voltage: 0.9V - 4.2V
Max Runtime:37 hours
Max Beam Distance: 107M
Peak Beam Intensity: 2880CD
ACEBEAM (SHENZHEN ZENBON TECHNOLOGY CO., LTD) RESERVES THE RIGHT TO EXPLAIN THE TERMS OF THE CONTEST.
Re: ACEBEAM Photo Contest for L30 GEN II / T36 / UC15
Publicado: 10 Ago 2018 11:11
por Noctiluco
En castellano, la cosa quedaría parecida a esto:
Queridos todos, ahora es el momento de ganar luces GRATIS (aplauso)
Las reglas son las siguientes:
1. Comentarios con las fotos de las tomas de rayos al aire libre debajo de este puesto (la foto DEBE ser iluminada por los productos de ACEBEAM sólo usted está utilizando y DEBE ser tomada por USTED);
2. Una vez seleccionada la foto, es necesario enviar a ACEBEAM las fotos claras enfocadas sin tomas borrosas en JPG con 1920 x 1000 píxeles;
3. ACEBEAM (SHENZHEN ZENBON TECHNOLOGY CO., LTD) tiene el derecho de utilizar las fotografías enviadas para fines de marketing.
Traducción realizada con el traductor http://www.DeepL.com/Translator
De nada, Acebeam :sisi1:
