ACEBEAM K65 Super Brightness Multipurpose Searchlight
Publicado: 17 Nov 2017 12:15
por Acebeam
Acebeam K65 - a new powerful hand flashlight, which is an improved version of the most popular flashlight K60. K65 adopts the Cree XHP70.2 de-moed LED, which allowed to increase the brightness of the light flux to 6200 lumens, also maximizes the output potential of the Cree XHP70.2 de-domed bulb with a peak beam intensity of 257000cd. In addition, K65 is distinguished by the increased luminous flux, which helps the beam distance up to 1014 meters. The rubberized pressure switch makes the operation much easier to cycling from all brightness levels. K65 is impressed by a thoughtful design and a high quality construction. The special surface structure makes the lamp firmly and securely in hand. K65 is an unmissable light when outdoor activities.
1*Cree XHP70.2 LED De-Domed
Turbo brightness output 6200 lumens
Ultra-long range beam distance 1014 meters
Powered by 4* 18650 batteries
Waterproof IPX-8 (2m Submersible)
Sizemm:190(length)*90(head dia)*53(tube dia)
Weight: 660g (23.3oz) without battery
The standard tripod socket meets various lighting demands when camping and photographing outside.
http://www.acebeam.com/newproducts
Re: ACEBEAM K65 Super Brightness Multipurpose Searchlight
Publicado: 18 Nov 2017 00:52
por Anthon
Awesome light! It's the first xhp70.2 light that I see throwing more than 1000m
