The Multifunctional 90° adjustable flashlight MT21C is relea
Subforo dedicado de Nitecore.
09 Abr 2018 08:41 por Nitecore
Profesional
Designed for multiple tasks, MT21C is a 1000 lumen 90° adjustable flashlight
The MT21C is a multifunctional adjustable work light, which double as either a compact EDC flashlight or an L-shaped work light. It gives all the versatility you need to handle any light task. It not only can be used as a streamlined flashlight, but also can be angled for 90 degrees to turn into a L-shape work light for industrial work, vehicle repair, outdoor adventure, law enforcement and so forth.
The MT21C utilizes a CREE XP-L HD V6 LED to emit a max output of 1000 lumens and a max throw of 184 meters. The adjustable head allows you adapt it to the right angle to get the job done. An integrated loop near the head allows a variety of attachment options such as the magnetic base allows for quick attach to any metal surfaces, and a metal loop enables the MT21C to be hung or suspended to other object, making it incredibly helpful for road-side auto-repair under the hood, workshop in the garage, tent frame or emergency light at home.
A metal switch controls 5 brightness levels and 3 special modes. With Advanced Temperature Regulation module, the MT21C regulates its output and adapts to the ambient environment, maintaining optimal performance. Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish, the MT21C is solid enough for various works.
For more about MT21C, please visit:http://flashlight.nitecore.com/product/mt21c
