P16TAC — An upgraded high intensity tactical flashlight buil
Publicado: 16 Ago 2017 12:45
por Nitecore
To meet the high requirement on shock resistance of tactical flashlight, Nitecore has released the new P16TAC, with strong shock resistance circuit design, ensures stable performance. Max output of 1000 lumens, 300 meters of beam distance and 600 hours runtime ensure excellent performance in military and tactical applications.
The strong shock resistance design protects the battery from getting loose or departure caused by the shooting recoil. The upgraded circuit double secures the shock absorption effect and meets the need of shooting or other shaky environments.
With one-handed operation user interface, the tactical tail switch allows for quick access to momentary and constant illuminations. A side switch controls 4 brightness levels and 3 special modes, making the P16TAC functional yet easy to operate.
It only takes one 18650 Li-ion battery to emit scorching 1000 lumens. The 18650 Li-ion battery offers higher power density, greater power storage performance and longer runtime than AA batteries.
Comes in a standard and compact size, P16TAC is equipped with stainless steel clip, compatible with multiple tactical accessories; Crenulated bezel design can serve as an effective tool in emergency; and the tail stand capability is convenient to use in any tactical scenarios.
IPX8 waterproof rating and 1.5 meters impact resistance, which makes P16TAC one’s first choice of military and tactical use.
For more info, please click:http://flashlight.nitecore.com/ILLUMINATION/P/P16TAC/
Re: P16TAC — An upgraded high intensity tactical flashlight
Publicado: 16 Ago 2017 14:25
"The similar tactical flashlight"... :facepalm2:
I am sure that "the similar tactical flashlight" uses an XPL HI led instead of a XML2 U3 and achieves greater range.
If you want to emphasize the beam distance of this flashlight, please use a more modern and specific led. If you want to emphasize the runtime, please, add a sublumen mode. This light seems to me an upgrade that is already obsolete before it comes to market. It rather seems that you are cleaning your storerooms.
Take note of Armytek Predator Pro XPL HI specifications. This is what many of us look for in a tactical flashlight.
Publicado: 16 Ago 2017 14:39
por Maiden666
Lfatman escribió:Take note of Armytek Predator Pro XPL HI specifications.
o mejor de su MH27 que se come en todo con patatas a la ArmyteK.
Publicado: 16 Ago 2017 19:41
Maiden666: Podríamos llenar este hilo de off topic sobre si la MH27 se come con patatas a la Armytek o no, pero el trasfondo del hilo seguirá siendo el mismo: han puesto un led un poco menos anticuado y ahora consiguen 40 lm más y 11 m más de alcance en la misma linterna. Esto no es un upgrade serio. Ni la regulación ATR han sido capaces de implementar.
Y encima nos venden la moto como si fuera el no va más de las linternas recurriendo a la cutrería publicitaria de comparar con la competencia... Si quieren presumir de alcance, que lo hagan en condiciones, como ya lo han hecho en otras series.
Eso sí, venderla a precio de upgrade sí lo están haciendo.
Para mí no merece la pena la P16 TAC , ahora que están liquidando a muy buen precio la P16 genuina en alguna tienda.
A ver si el representante de Nitecore en el foro se digna a comentar algo al respecto por una vez.
