[REVIEW] ZHISZHISHUNJIA BX2
Subforo dedicado de DealExtreme.
03 Feb 2019 14:30 por DealExtreme
Profesional
ZHISZHISHUNJIA BX2
General
Product model: BX2
Radiation distance: 300-500 meters
Lighting brightness: 1600 lumens
Bracket type: 360 degree rotating bracket
Charge and discharge protection: built-in overcharge and discharge IC to extend battery life.
Electricity indication: electricity is enough, LED lights are green, electricity is weak red.
Charge indication: LED is red when charged, green after electricity.
Product specification: total length 120mm, width 40mm, thickness 80mm
Light modulation mode: strong light, medium light, blasting flash
Working voltage: 3.7V
Barrel color: Black
Light color: cold and white light
Lamp color temperature: 7500K
Barrel material: aluminum alloy
Endurance time: 3 hours /6 hours
Power supply: built-in single section 18650
Surface treatment: wear-resistant anodic oxidation
Switch type: light head press switch
Waterproof grade: IPX5 (prevent rain, splash water)
Product accessories: car lights, brackets, 0.5 meters USB line, packaging
