Novatillo buscando primera linterna Led.
D40A is another superior Sunwayman AA type flashlight introduced. Powered by 4*AA batteries, inexpensive and widely available power source, very compact and solid structure, smaller yet stronger. This light is able to maintain high output as well as long runtime, built with Sunwayman’s new dual-button side switch system, exquisite design with great hand-feel. Fitted with premium CREE XM-L2 LED, output up to 980 lumens, combined with the optimized deep reflector, the effective range reaches 315 meters. The D40A is your great lighting tool in the dark for searching, observation and much more.
Features
● CREE XM-L2 LED, with a lifetime of up to 50,000 hours;
● Brand-new Dual-button Side Switch System, slightly depress the side switch buttons for output ranging from 30 to 980 lumens, Police Strobe, Aviation Signal, SOS, Strobe and Moon Mode:
Turbo: 980 Lumens (To avoid overheating, the light will enter High mode automatically after 3mins continuous use)
High: 550 Lumens (1.7hrs)
Mid: 220 Lumens ( 4hrs )
Low: 30 Lumens (31hrs)
● Constant current circuit, constant output;
●Standby Current: < 30μA
● Effective range of 315 meters;
● Intensity: 24800cd;
● Uses 4* AA (alkaline, NI-MH, nickel-cadmium) batteries;
● High quality reflector with soft beam pattern;
● Working voltage: 3~6V;
● Optimized deep metal reflector, great throw distance as well as perfect beam pattern;
● Dimension: 120.6mm (length) x 40mm (head diameter) x 42mm (body diameter)
● Weight: 165.4g (battery excluded);
● High quality aerospace-grade aluminum alloy, Stainless steel head retaining ring;
● Military specification Type III- hard anodized body;
● Waterproof, in accordance with IPX-8 standard;
● Ultra-clear tempered glass lens resists scratches and impacts;
● Tail stand capable- can be used as a candle
● Accessories: Lanyard, O-ring, Holster
Con el nivel y las linternas que se ven en el foro supongo que ésta entraría en el rango medio-bajo, pero para lo que busco como primera compra no sé si consideráis que me podría servir o se me quedaría corta. El precio por el que la podría conseguir estaría sobre los 58€.
