Nueva Olight S Mini
Publicado: 22 Oct 2016 16:07
No se si ya lo habeís comentado en algún otro hilo...
¡¡Bastante más pequeña que la S1!! :eek:
La hay de cobre con XM-L2 CW (Raw, Rose Gold y Black) y de Titanio con XM-L2 NW (Polished, Bead Blasted y Rainbow PVD).
Yo ya he pedido de momento una Ti Polished...
MP si queréis un descuentillo. :respeto:
Re: Nueva Olight S Mini
Publicado: 22 Oct 2016 16:26
por kreisler
yo quiero :llora:
Publicado: 22 Oct 2016 16:30
kreisler escribió:yo quiero :llora:
MP inbound! :eaea:
Publicado: 22 Oct 2016 16:32
por kreisler
:paysent:
:cantarin:
Publicado: 22 Oct 2016 18:11
por Trevilux
Yo voy por la Rainbow PVD :)
Publicado: 22 Oct 2016 19:57
Mándame los datos, please, que tengo que hacer un regalo.
Publicado: 23 Oct 2016 10:47
por Noctiluco
A mí me interesa la de cobre en acabado PVD negro, Te envío MP
Publicado: 23 Oct 2016 13:30
Respondidos todos los MPs!
Ampliando un poco la info, en la web de Olight dice lo siguiente:
The S Mini Baton is the smallest CR123A battery compatible flashlight ever produced by Olight. The limited edition premium materials used are Copper and Titanium in various finishes and colors. Powered by one CR123A battery, the S Mini has four levels of brightness plus a strobe mode and covers a range from 0.5 to 550 lumens. Compared to the original S1 Baton, the S mini has a 10% shorter length and a 10% increased maximum output to 550 lumens. The S mini uses red copper and titanium alloy as its body material and has six different versions to choose from. This is a premium flashlight reflecting refined workmanship, assembly, and PVD processing technology.
FEATURES
  • Utilizes a cree XM-L2 LED paired with a high light transmission rate TIR Optic lens
  • Two color temperatures: cool white on the copper versions. Neutral white for the titanium versions
  • Compared to the original S1 Baton, the S mini has a 10% shorter length and a 10% increased maximum output to 550 lumens.
  • Gradual brightness change: When the light is turned on or off, the light will gradually fade on or off to not strain the eyes during brightness changes
  • Highly scratch and corrosion resistant through PVD processing
INCLUDED ACCESSORIES
  • Flashlight (with stainless steel clip) x 1
  • 1600mAh CR123A Battery x 1
  • Instruction Manual
En resumen, un 10% más corta, y un 10% más potente (50LM más que la S1). Cambio gradual de brillo ( :zpalomita: ). No menciona nada sobre las funciones "especiales" como el autoapagado de la S1. Al parecer pierde también el difusor cónico incluido de serie.
También hay la siguiente table:
Publicado: 24 Oct 2016 10:05
por tigerhawkes
En que tiendas la habeis visto?
A parte de la de Olight no la veo.
Publicado: 24 Oct 2016 17:50
por Noctiluco
tigerhawkes escribió:En que tiendas la habeis visto?
Pregunta por mensaje privado a UPz; por cierto, recibido mp, gracias!
Publicado: 25 Oct 2016 11:48
Ya le pasé la info de la tienda y el precio por MP.
Ya hay una breve review:
Y algunas fotos más van apareciendo..
Por cierto, yo ya tengo mi tracking. :up:
Publicado: 26 Oct 2016 17:47
Mas fotos...
Al parecer la S-Mini no tiene imán, pero como se puede ver el tailcap es compatible, por si esa función fuese importante para nosotros. Eso si, con el tailcap de la S1 la longitud es la misma entrte ambas :elboinas:
Publicado: 26 Oct 2016 21:01
por UVE
Una pregunta
El color dorado de la rose gold se lanzara a perder con el uso ?
Visto lo visto con la raw copper...
Toda informacion sera bienvenida. :elboinas: :respeto:
Publicado: 27 Oct 2016 14:09
por Puntxa
Muy bonita este modelo.
Me puedes pasar el link para su compra :cejas:
Publicado: 27 Oct 2016 15:50
por illustratum
A mi también podría interesarme pedir una.
Una preguntita de principiante. ¿Esta es segura para que la use un niño? o se puede calentar mucho dado su diminuto tamaño
Publicado: 27 Oct 2016 15:58
por trevize
Personalmente, para un niño una linterna de AA o AAA me parece más segura.
Publicado: 27 Oct 2016 23:34
por 944
illustratum escribió: ¿Esta es segura para que la use un niño? o se puede calentar mucho dado su diminuto tamaño
Yo el inconveniente que veo es que alumbre a sus propios ojos o a los de los demas. Si tiene esto claro y que no haga tonterías con la batería...no veo mas problema.
¿Alguien ha jugado con las pilas de petaca en la lengua? no creo que sea yo el único :roto2rie: :qmeparto
Publicado: 27 Oct 2016 23:43
Ni por tamaño ni, sobretodo, por precio creo que sea una linterna para darsela a un crio. La veo "cara", pequeña (facil de perder) y quizás demasiado potente. Una AA de 80-100LM sería más acertado imho.
Por cierto, ¿alguien ha visto algo sobre la loteria que Olight hace con el número de serie de la S-Mini?
Publicado: 27 Oct 2016 23:57
por illustratum
No me refería a regalársela sino a que la pudiera manipular mi sobrino de 10 años.
La linterna sería para el menda, pero seguro que si me la viera la querría usar un rato. Mi preocupación es por la temperatura. (sólo era una duda que aproveché para consultar, supongo que es algo que podré comprobar yo mismo) Ya aclaré que soy novato en todo esto pero no un irresponsable.
Si me pudierais indicar donde comprarla y el precio. He visto el modelo anterior pero ya que hay uno nuevo
Publicado: 28 Oct 2016 16:07
por F. Premens
Soy al unico al que no le llama? :elrisas:
