Nueva version - Thrunite TN30 y TN31
Thrunite TN31
LED: Cree XM-L2 LED with a lifespan of 20+years of run time.
· Max 1376 lumen output using 3 * 18650 batteries.
· Level 1: 0.6 lm. 2000 hours; Level 2: 23 lm. 140 hours; Level 3: 175 lm. 22 hours; Level 4: 439 lm. 9 hours;
· Level 5: 744 lm. 5 hours; Level 6: 1376 lm. 2 hours; Standby: 65 uA; Strobe: 1376 lm. 4 hours.
· Working voltage: 4V to 13V.
· Max runtime: 2000 hours.
· Max beam distance: 840 meters.
· Peak beam intensity: 90000cd.
· Impact resistant: 1.2 meters.
· Waterproof to IPX-8 standard, 2M.
· 201.70mm length, 79.00mm bezel diameter.
· Weight: 452.80g without battery.
· Aircraft grade aluminum body structure.
· Premium type III hard anodized anti-abrasive finish.
· Ultra-clear tempered glass lens with anti-reflective coating.
· Momentary forward click tactical switch.
· Strobe mode for tactical and emergency use.
· Smooth reflector for max light output.
· Highly focused beam for maximum distance.
· Tactical knurling for firm grip.
· Streamlined body design.
· Mechanical reversed polarity protection design for battery carrier.
· Intelligent highly efficient circuit board design for max performance and long run time.
· Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoor activities.
· Intelligent temperature controlled light output for user safety.
