¿QUE OS PARECE ESTA HID?
Aqui os dejo el enlace...no tiene mala pinta
Specifications:
* Brightness: >2000LM
* Color temperature: 6000K
* Optical efficiency: 60LM/W
* Irradiation distance: ≤800m
* Ballast input voltage: 9V~16V
* Working Voltage: 12V
* Working current: 3.2A
* Starting Max current: <8A
* Power output: 24W
* Output temporary max voltage: 23KV Max
* Battery Mode?ICR18650 (2200mAh)
* Battery charging voltage: 12.6V±~0.1V 2.0A
* Battery lifespan (charging and discharging times): ≥500 times
* Bulb life-span: 3000 hours
* Continual illuminating time: 90 mins
* Working environment: -15~+50 celes degree
* Starting environment: 0~+50 celes degree
* Waterproof degree: IPX3 Waterproof
* Packing: Stainless aluminum alloy tool case
* Color: Black (as shown in the pictures)
* Length: 23.5cm
* Lamp holder diameter: 5cm
* Net weight: 0.7kg
* Gross weight: 1.58kg
* Case size: 26.5*18*9.5cm
