The Torch, 4100 lumens
Mirando el otro dia unas webs de lasers tienen esta linterna, sirve para hacer huevos fritos.
http://www.wickedlasers.com/lasers/The_Torch-74-41.html
Currently being reviewed by The Guinness Book of World Records, The Torch is the world's brightest and most powerful flashlight. This flashlight is easily capable of melting plastic, lighting paper on fire within seconds, and if you want, frying an egg or a marshmallow on a stick! At 4100 lumens, The Torch is 100 lumens more powerful than The Polarion Helios, the former most powerful flashlight. Looking to buy a bright flashlight? This flashlight torch will not disappoint you.
So how did we make such a powerful, bright flashlight? The Torch uses an incredible halogen light bulb rated at 100 Watts and runs on a custom built high voltage rechargeable battery. To keep the front lens from shattering due to the immense heat generated, The Torch flashlight is equipped with a specialized heat resistant glass lens and is encased in a durable, military grade aluminum case. Check out The Torch flashlight in action below.
Technical Specs
[TABLE][TR][TD]Name:[/TD][TD]The Torch [/TD][/TR][TR][TD]Lamp Output:[/TD][TD]4100 Lumens with an Adjustable High Efficiency Reflector [/TD][/TR][TR][TD]Dimensions:[/TD][TD]57mm x 230mm[/TD][/TR][TR][TD]Power Supply:[/TD][TD]12x2/3A 1500mAh Cells 14.4V[/TD][/TR][TR][TD]Battery Lifetime:[/TD][TD]15 Minutes[/TD][/TR][TR][TD]Bulb Type:[/TD][TD]100W Halogen[/TD][/TR][TR][TD]Expected Bulb Life:[/TD][TD]2000 Hours[/TD][/TR][TR][TD]Casing:[/TD][TD]Aerospace Grade Aluminum[/TD][/TR][TR][TD]Tail switch:[/TD][TD]On/Off Button[/TD][/TR][TR][TD]Warranty:[/TD][TD]6 Months[/TD][/TR][/TABLE]
Video haciendo huevos fritos
http://www.youtube.com/v/wsIHyRyETKg
Manual
http://www.wickedlasers.com/download/To ... 0Guide.pdf
Precio 299,99$
En esta otra web, aparecen otras.
http://www.rayfoss.com/pro_list.asp?catid=617
![Imagen](http://www.forolinternas.com/images/smilies/roto2.gif)
Technical Specs
Manual
Precio 299,99$
