Nueva Olight S Mini
![Imagen](http://i575.photobucket.com/albums/ss200/rookiedaddy/Flashlights/Olight/SMini/Smini_800.jpg)
![Imagen](http://uploads.tapatalk-cdn.com/20161021/d81daf95fcc02d31f5531ef3aea71a8c.jpg)
![Imagen](http://uploads.tapatalk-cdn.com/20161015/34970c778799bd3ab99b48faf42213a8.jpg)
¡¡Bastante más pequeña que la S1!!
![eek :eek:](./images/smilies/eek.gif)
![Imagen](http://www.olightstore.com/image/cache/catalog/products/flashlights/Smini/Ti/s-mini-ti-1-750x750.jpg)
![Imagen](http://www.olightstore.com/image/cache/catalog/products/flashlights/Smini/Ti/s-mini-ti-2-750x750.jpg)
![Imagen](http://www.olightstore.com/image/cache/catalog/products/flashlights/Smini/Ti/s-mini-ti-13-750x750.jpg)
![Imagen](http://i575.photobucket.com/albums/ss200/rookiedaddy/Flashlights/Olight/SMini/WhatILikeToCallThemSMini.png)
La hay de cobre con XM-L2 CW (Raw, Rose Gold y Black) y de Titanio con XM-L2 NW (Polished, Bead Blasted y Rainbow PVD).
Yo ya he pedido de momento una Ti Polished...
En resumen, un 10% más corta, y un 10% más potente (50LM más que la S1). Cambio gradual de brillo (The S Mini Baton is the smallest CR123A battery compatible flashlight ever produced by Olight. The limited edition premium materials used are Copper and Titanium in various finishes and colors. Powered by one CR123A battery, the S Mini has four levels of brightness plus a strobe mode and covers a range from 0.5 to 550 lumens. Compared to the original S1 Baton, the S mini has a 10% shorter length and a 10% increased maximum output to 550 lumens. The S mini uses red copper and titanium alloy as its body material and has six different versions to choose from. This is a premium flashlight reflecting refined workmanship, assembly, and PVD processing technology.
FEATURES
- Utilizes a cree XM-L2 LED paired with a high light transmission rate TIR Optic lens
- Two color temperatures: cool white on the copper versions. Neutral white for the titanium versions
- Compared to the original S1 Baton, the S mini has a 10% shorter length and a 10% increased maximum output to 550 lumens.
- Gradual brightness change: When the light is turned on or off, the light will gradually fade on or off to not strain the eyes during brightness changes
- Highly scratch and corrosion resistant through PVD processing
INCLUDED ACCESSORIES
- Flashlight (with stainless steel clip) x 1
- 1600mAh CR123A Battery x 1
- Instruction Manual
Pregunta por mensaje privado a UPz; por cierto, recibido mp, gracias!tigerhawkes escribió:En que tiendas la habeis visto?
A parte de la de Olight no la veo.
Yo el inconveniente que veo es que alumbre a sus propios ojos o a los de los demas. Si tiene esto claro y que no haga tonterías con la batería...no veo mas problema.illustratum escribió: ¿Esta es segura para que la use un niño? o se puede calentar mucho dado su diminuto tamaño
