Thrunite T20 + T1 free
Publicado: 09 Oct 2012 20:16
Bueno gente, no me quedó otra opcion que pedir la Thrunite T20 + la T1 free.
Le tuve que explicar a mi esposa que la culpa es de ForoLinternas
, que si hubiese sido por mi no la compraba..
Specifications:
- Cree XP-G LED (R5) with lifespan of 50,000 hours
- Three modes of output: High (185 lumen, 1.8hrs) -> Low (22lumen, 13hrs ) -> firefly(0.09lumen 195hours) with memory
- Stable current regulated circuit, stable brightness
- Uses one 3V CR123a battery. 16340 batteries are not recommeded, because they heat up quickly.
- 19-gram weight (excluding batteries)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Waterproof to IPX-8 Standard
- Toughened double ultra-clear glass lens
- Reliable twist switch
- Candle mode (Capable of standing up securely on a flat surface to serve as a candle)- Accessories: key ring.
- Size: 63x20mm
Promotion:
Notice:
Ti is promotion for free
3 lumen version: All five colors black, blue, red, green, gold are available.
Ti specifications:(3-60 lumen version)
- Uses Cree XP-E R4 LED with a lifespan of 50000 hours
- Uses one 0.9-1.5V AAA (Ni-MH, Alkaline) battery
- 7.2cm (Length) x 1.4cm (Diameter)
- 20-gram weight (excluding batteries)
- OP reflector
- Reverse polarity protection, to protect from improper battery installation
- Reliable twist switch. Tighten for Firefly (3lumen) tighten further for max Output (60 lumen)
Operation:
Slightly twist the head tighten to firefly(3 lumen), tighten further for max output (60Lumen)//www
Specifications:
- Size: 63x20mm
Promotion:
Notice:
- OP reflector
Operation:
