Tipos de Leds listados por potencia (Lúmens)
30 Dic 2009 01:51 por XRAYBoY
5MM Generic LEDs (0.5-5 Lumens ea)
5MM Nichia LEDs (5-10 Lumens ea)
"High Power" LED (10-70 Lumens)
Luxeon I (40 Lumens @ 350ma)
Nichia IO Moon (45 Lumens @ 350ma)
Luxeon III (80 Lumens @ 1000ma)
Luxeon V (87-120 Lumens @ 700ma)
CREE P2 (67-73 Lumens @ 350ma)
CREE P3 (73-80 Lumens @ 350ma)
Luxeon Rebel 80 (80 Lumens @ 350ma)
CREE P4 (80-87 Lumens @ 350ma)
Luxeon K2 PWC4 (85 Lumens @ 350ma, 250lm at 1500ma)
SSC P4 T Bin (70-91 Lumens @ 350ma)
CREE Q2 (87-94 Lumens @ 350ma)
CREE Q3 (94-100 Lumens @ 350ma)
Luxeon Rebel (100 Lumens @ 350ma)
Edison Optics KLC8 (100 Lumens @ 350ma)
CREE Q4 (100-107 Lumens @ 350ma)
SSC P4 U Bin (91-118 Lumens @ 350ma)
CREE Q5 (107-114 Lumens @ 350ma)
Osram Golden Dragon Plus Ultra White (120 Lumens @ 350ma)
CREE R2 (114-120 Lumens @ 350ma)
CREE XPG R3 (122-130 Lumens @ 350 mA)
CREE XPG R4 (130-139 Lumens @ 350 mA)
CREE XPG R5 (139-148 Lumens @ 350 mA)
CREE MC-E K Bin (370-430 Lumens @ 350ma x4)
CREE MC-E M Bin (430-490 Lumens @ 350ma x4)
SSC P7 B Bin (570-700 Lumens @ 2800ma)
SSC P7 C Bin (700-800 Lumens @ 2800ma)
SSC P7 D Bin (800-900 Lumens @ 2800ma)
Luminus SST-50 H-bin (999-1175 lm @ 5A)
Luminus SST-50 J-bin (1175-1410 lm @ 5A)
Luminus SST-50 K-bin (1410-1645 lm @ 5A)*
Luminus SST-90 K-bin (1410-1645 lm @ 9A)
Luminus SST-90 L-bin (1645-1998 lm @ 9A)
Luminus SST-90 M-bin (1998-2350 lm @ 9A)
Luminus SST-90 N-bin (2350-2820 lm @ 9A)
Luminus SST-90 P-bin (2820-3408 lm @ 9A)*
Se irá editando y añadiendo según haya novedades...
Lumens @ 350mA
Tabla de potencias de varios tipos de leds:
Tabla del Cree XRE Q5
Curvas del XP-G R5
Imagen Imagen
Rojo: XP-G R5 // Blanco: 2x XP-E R2 (en paralelo)
Curva de potencia del SST-50
Curva de potencia del SST-90
Led Cree XM-L
Cree XM-L @350mA:
T5-bin 134 - 140 Lumens
T6-bin 144 - 150 Lumens
U2-bin 154 - 160 Lumens
Cree XM-L @700mA:
T5-bin 260 - 280 Lumens
T6-bin 280 - 300 Lumens
U2-bin 300 - 320 Lumens
Cree XM-L @3.0A (+325%)
T5-bin 845 - 910 Lumens
T6-bin 910 - 975 Lumens
U2-bin 975 - 1040 Lumens
Vf de 2,8 V a 350 mA y Vf de 3,4 V a una corriente de 3A.
Tonos según Bin.
Comparativa leds XM-L vs XPG vs XPE:
http://budgetlightforum.com/node/19331
Para conocer con mayor precisión estos y otros tipos tipos de leds y bins: http://www.forolinternas.com/viewtopic.php?f=22&t=6583 :respeto:
28 Mar 2010 17:34 por kiky
Re: Tipos de Leds listados por potencia (Lúmens)
que le es el s2?, no lo he oido nunca?, se podría añadir a la tabla la superficie de cada led?
gracias
28 Mar 2010 21:31 por XRAYBoY
El "S2" va con interrogante,por que es una presunción del próximo led que sacarían,el base a como suben habitualmente de potencia.
Realmente,creo que no existe (todavía).
En la pagina web de cada fabricante,dispones de las especificaciones técnicas de cada led,incluyendo sus medidas.
08 Abr 2010 22:53 por zer01
Cree XR-E, XP-E & XP-G brightness at 350mA
P4 80.6-87.4 lm @ 350mA
Q2 87.4-93.9 lm @ 350mA
Q3 93.9-100 lm @ 350mA
Q4 100-107 lm @ 350mA
Q5 107-114 lm @ 350mA
R2 114-122 lm @ 350mA
R3 122-130 lm @ 350mA
R4 130-139 lm @ 350mA
R5 139-148 lm @ 350mA
S2 148-156 lm @ 350mA
Cree XR-E and XP-E brightness at 1A
P4 177-192 lm @ 1A
Q2 192-207 lm @ 1A
Q3 207-220 lm @ 1A
Q4 220-233 lm @ 1A
Q5 233-251 lm @ 1A
R2 251-268 lm @ 1A
R3 268-286 lm @ 1A*
R4 286-306 lm @ 1A
Cree XP-G brightness at 1A
R2 285-305 lm @ 1A
R3 305-325 lm @ 1A
R4 325-348 lm @ 1A
R5 348-370 lm @ 1A*
S2 370-390 lm @ 1A
Cree XP-G brightness at 1.5A
R2 380-406 lm @ 1.5A
R3 406-433 lm @ 1.5A
R4 433-463 lm @ 1.5A
R5 463-493 lm @ 1.5A*
S2 493-520 lm @ 1.5A
Cree MC-E brightness at 350mA per die, 1.4A total current
H 280 - 320 lm @ 350mA (1.4A)
J 320 - 370 lm @ 350mA (1.4A)
K 370 - 430 lm @ 350mA (1.4A)
M 430 - 490 lm @ 350mA (1.4A)*
N 490 - 560 lm @ 350mA (1.4A)
MC-E brightness at 700mA per die, 2.8A total current
H 490 - 560 lm @ 700mA (2.8A)
J 560 - 648 lm @ 700mA (2.8A)
K 648 - 753 lm @ 700mA (2.8A)
M 753 - 858 lm @ 700mA (2.8A)*
N 858 - 980 lm @ 700mA (2.8A)
Luminus SST-50 brightness at 1.75A, 350mA per mm²
F 275-350 lm @ 1.75A (350mA/mm²)
G 350-425 lm @ 1.75A (350mA/mm²)
H 425-500 lm @ 1.75A (350mA/mm²)
J 500-600 lm @ 1.75A (350mA/mm²)*
K 600-700 lm @ 1.75A (350mA/mm²)
Luminus SST-50 brightness at 2.8A, 560mA per mm²
F 413-525 lm @ 2.8A (560mA/mm²)
G 525-638 lm @ 2.8A (560mA/mm²)
H 638-750 lm @ 2.8A (560mA/mm²)
J 750-900 lm @ 2.8A (560mA/mm²)*
K 900-1050 lm @ 2.8A (560mA/mm²)
Luminus SST-50 brightness at 5A, 1A per mm²
F 635-823 lm @ 5A (1A/mm²)
G 823-999 lm @ 5A (1A/mm²)
H 999-1175 lm @ 5A (1A/mm²)
J 1175-1410 lm @ 5A (1A/mm²)*
K 1410-1645 lm @ 5A (1A/mm²)
Luminus SST-90 brightness at 3.2A, 350mA per mm²
K 600-700 lm @ 3.2A (350mA/mm²)
L 700-850 lm @ 3.2A (350mA/mm²)
M 850-1000 lm @ 3.2A (350mA/mm²)
N 1000-1200 lm @ 3.2A (350mA/mm²)*
P 1200-1450 lm @ 3.2A (350mA/mm²)
Luminus SST-90 brightness at 5A, 560mA per mm²
K 882-1029 lm @ 5A (560mA/mm²)
L 1029-1250 lm @ 5A (560mA/mm²)
M 1250-1470 lm @ 5A (560mA/mm²)
N 1470-1764 lm @ 5A (560mA/mm²)*
P 1764-2132 lm @ 5A (560mA/mm²)
Luminus SST-90 brightness at 9A, 1A per mm²
K 1410-1645 lm @ 9A (1A/mm²)
L 1645-1998 lm @ 9A (1A/mm²)
M 1998-2350 lm @ 9A (1A/mm²)
N 2350-2820 lm @ 9A (1A/mm²)*
P 2820-3408 lm @ 9A (1A/mm²)
Seoul SemiConductor P4 brightness at 350mA
S1 54-60 lm @ 350mA
S2 60-70 lm @ 350mA
T1 70-80 lm @ 350mA
T2 80-91 lm @ 350mA
U1 91-100 lm @ 350mA
U2 100-109 lm @ 350mA*
U3 109-119 lm @ 350mA
Seoul SemiConductor P4 brightness at 1A
S1 127-141 lm @ 1A
S2 141-165 lm @ 1A
T1 165-188 lm @ 1A
T2 188-214 lm @ 1A
U1 214-235 lm @ 1A
U2 235-256 lm @ 1A*
U3 256-280 lm @ 1A
Seoul SemiConductor P7 brightness at 1.4A total current, 350mA per die
A 251-326 lm @ 1.4A (350mA)
B 326-400 lm @ 1.4A (350mA)
C 400-457 lm @ 1.4A (350mA)
D 457-514 lm @ 1.4A (350mA)*
E 514-629 lm @ 1.4A (350mA)
Seoul SemiConductor P7 brightness at 2.8A total current, 700mA per die
A 440-570 lm @ 2.8A (700mA)
B 570-700 lm @ 2.8A (700mA)
C 700-800 lm @ 2.8A (700mA)
D 800-900 lm @ 2.8A (700mA)*
E 900-1100 lm @ 2.8A (700mA)
Lumileds Luxeon Rebel brightness at 350mA
040 40+ lm @ 350mA
050 50+ lm @ 350mA
060 60+ lm @ 350mA
070 70+ lm @ 350mA
080 80+ lm @ 350mA
090 90+ lm @ 350mA
100 100+ lm @ 350mA*
110 110+ lm @ 350mA
Lumileds Luxeon Rebel brightness at 1A
040 84+ lm @ 1A
050 105+ lm @ 1A
060 126+ lm @ 1A
070 147+ lm @ 1A
080 168+ lm @ 1A
090 189+ lm @ 1A
100 210+ lm @ 1A*
110 231+ lm @ 1A
*(maximum available flux bin as of writing)
Sources:
http://www.cree.com/products/xlamp_docs.asp
http://www.luminus.com/content1454
http://www.acriche.com/en/product/prd/zpowerLED.asp
http://www.philipslumileds.com/products ... ebel-white
09 Abr 2010 12:28 por XRAYBoY
Excelente trabajo Zer01 Imagen
09 Abr 2010 16:17 por zer01
XRAYBoY escribió:Excelente trabajo Zer01 Imagen
Si, ya me gustaria, pero es de un enlace que puso alguien en este foro a una pagina del blog de DX (si me llego a callar, cuela Imagen)
15 Abr 2010 17:25 por Quemapilas
Osea que si me compro una linternita, que tenga el cree XR-G S2, si es un P7, la revisión E.
La oscuridad es barata.
20 Ago 2010 20:15 por XRAYBoY
Añado unas gráficas en el primer post, ya que los SST-50 y SST-90 ya empiezan a salir a la luz. Imagen
20 Ago 2010 22:46 por moviles2
esas graficas me suenan de hace mucho creo son antiguas de cuando no se podian conseguir bin especificos sino solo muestras sin bin especifico como el primero que yo compre en julio del año pasado
vamos que las graficas no son de los bin mas altos disponibles ahora
23 Sep 2010 01:02 por LUMEXX
Baneado
ya decia yo que no me cuadran los datos , pense que tenia un error yo, :)
23 Sep 2010 01:44 por XRAYBoY
¿Y a que esperáis para poner las nuevas? Imagen Imagen
01 Dic 2010 11:46 por Quemapilas
Este hilo merece chincheta, porque es siempre una tabla a consultar. Muchas veces tienes los datos del diodo y del consumo y puedes hacer estimaciones de luz.
01 Dic 2010 11:52 por fran82
y añadir xm-l?
01 Dic 2010 19:44 por XRAYBoY
Encantado de que pongáis todas las novedades...así podremos consultarlas cuando haga falta.
Si las veis por ahí CTRL+C ... CTRL+V. Fácilmente hoyga!
02 Dic 2010 09:55 por fran82
Podeis añadir esto que he obtenido del XM-L?
Cree XM-L @350mA:
Cree XM-L @700mA:
Cree XM-L @3.0A gives 325% more flux:
Vf de 2,8 V a 350 mA y Vf de3,4 V a una corriente de 3A.
Mas INFO aqui http://translate.google.com/translate?s ... -az-160lmw
16 Ene 2011 01:47 por fer18gts
11 May 2011 17:13 por bacardis
teneis que actualizarlo me parece :silbando:
11 May 2011 18:15 por varamigue
bacardis escribió:teneis que actualizarlo me parece :silbando:
¿Y podrias decir en que ?
01 Dic 2011 14:54 por Me pirro todo
Buenas
Podría alguien decirme algún sitio donde pudiera ver de forma clara las principales diferencias entre los XR-E, XP-G, superficie die, ángulo de emisión, esas cosas...
01 Dic 2011 20:05 por XRAYBoY
Directamente en la web de los fabricantes, por ejemplo: http://www.cree.com/products/ledlamps.asp
En los datasheets de cada led vienen todos esos detalles...
